Mastermind PBC Firmware / Editor 5.3.3 Release
Status
Not open for further replies.
Hi, I can't understand why it started working on 5.3.1 and stopped on 5.3.2 after restoring to default and copying a few buttons over. May I send my rjm file?
It looks like what I did to fix fuzz mode in 5.3.0 stops the tuner from working when buffer 1 is turned off. I have a change that will go into 5.3.3 that fixes this. I don't have an explanation as to why it would work in 5.3.1, it shouldn't, unless the buffer was enabled when you were using 5.3.1.
In any case, the tuner now works with buffer on and buffer off, and with fuzz mode on and fuzz mode off. And, fuzz mode continues to work properly. It all should work for you as well.
This makes sense! My tuner stopped working after 5.3.0 and I discovered turning on Buffer 1 brought it back... Should have reported that!
Version 5.3.3 now available, fixes the tuner issue mentioned and some other things. Details at the top of the thread.
for some reason I can't figure after updated to 5.3.3 my delay module keep turning off no matter how many time I save the preset ( ON MY KEMPER PLAYER ) with the delay on . Any idea what i might be doing wrong ?
  • PROBLEM s .rjs
The Mastermind's Delay button is programmed to send its state to the Kemper Player on every preset change, it's overriding the settings in the Kemper. Try turning off Send on Preset Change on the button and see if that fixes it.
will try that later tonight thank you
Status
