EVHGuy1111
I have the MEGX. Love it. It's set up in the 4-cable method configuration.
The amp I run is an EVH 515OIII 5Ow 6L6.
I'm going to build a Wet/Dry setup with another 515OIII 5Ow, but the EVH salve routing requires:
MASTER AMP preamp out > SLAVE AMP effects loop return
How do I route the MEGX to have:
• effect pedals in front of MASTER AMP
• wet effect pedals in loop of SLAVE AMP
• maintain the slaving so SLAVE AMP receives all MASTER AMP's settings
Best I can figure is:
GUITAR > MEGX in
MEGX snd 3 > MASTER AMP (Front) insert
MASTER AMP preamp out > MEGX rtn 3
MEGX out > SLAVE AMP effect loop return
Amp Channel Changing
MEGX midi out > midi thrubox > MASTER AMP midi and SLAVE AMP midi (simultaneously)
If I have no idea what I'm doing and will blow up these amps, please tell me...
Please offer some insight how I should route this to achieve the desired rig, or some insight if I have to purchase an ABY box to run both amps simultaneously if slaving is not possible.
Great forum!
Thank you!
GUITAR > MEGX in
Great forum!
Thank you!
