Micro line mixer help!
Is this possible to do with this Micro Line Mixer?
I am using a prophet keyboard that is mono out and want to go into the line mixer from there go out of the buffer out (mono) and then go into two Strymon pedals, both running kill dry. From here I will split into stereo and mix everything down and go out of the line mixer stereo? Are there any issues y'all see? and phasing issues? It essentially just seems to be a wet/dry/wet mixed down to stereo.
Thanks,
Chris
You're welcome!
Okay Mario I need some help. So I've troubleshooted a lot and trying to figure out where the issue is now. I'm going mono into the line mixer on the dry in (jumper is set to mono). The buffer out is set to going TRS to dual TS (dry out jumper is set to stereo). Now I'm taking one of the TS cables out of the buffer out and sending it to a Strymon Mobius and another TS cable out going to a Strymon bigsky.
From here I want to go out of the Mobius and Bigsky dual TS to TRS into Wet in 1 and Wet in 2. When I go directly out from the strymons to my interface they sound sound stereo but as soon as I put them into the Wet 1 and 2 they seem to collapse to mono. Any idea on what could be causing this?
Thanks
Hey Chris,
Your Micro Line Mixer internal jumper settings are correct, but I would check them again, just to be sure.
Check all of your cables, even if they are new - we have definitely seen an increase in new cables being bad, from all sorts of suppliers.
On both Strymon's, make sure you are using the LEFT input as the mono input. Make sure both pedals also have kill-dry enabled. I'm not sure if there are any other parameters that need to be set, but check that.
On the Mobius, make sure the rear panel switch is set for Stereo In/Out.
