MIDI merge not working correctly
ralphonz
I have BCR2000 midi controller. I've assigned a rotary to transmit CC19 on channel 1 (which controls external parameter 4 on my axe fx). When i plug the BCR straight into the MIDI in on the axe it is working fine and controlling the parameter.
However, when I plug it into the remote in on the GT/16 and turn on MIDI merge, the axe receives only a very brief midi message from the BCR rather than any continuous data. It seems as though the MIDI data from the BCR is not merged and sent out properly. Bug?
My goal is to have some rotary pots next to the GT that I can use as external controllers for parameters on the axe. It'd be great if could stick to the single cable running from the GT to the axe by using the remote in.
Anyone got any advice here? I still can't get the BCR to work when going through the Mastermind. Only when I go into the axe directly...
