Mission SP1-RJM Spring Load Inspiration
Dallas
So pumped to have just received a Mission SP1-RJM with Spring Load. Now I'm trying to figure out what to do with it, so I'm looking for suggestions.
For reference, I am using a Mastermind GT with my Kemper. I usually have all Kemper fx blocks occupied with compression, overdrive, eq, delays and reverbs, so I don't usually have room for wah or pitch.
In light of the above, how would you suggest using an SP1-RJM Spring Load? What would you program into the switch function?
Everything is on the table!
I have a Mission springloaded with my gt22 and axe fx3 i have always used the springloaded for wah with autoengage if not i sometimes use it for mix on effects on reverb its really cool or for multi delays to create a synt/Stringer sound
Auto-engaging wah and whammy are what usually get assigned to my spring-loaded Mission expression pedal. I've occasionally used it for flanger parameters adjustments too. All on Fractal devices.
