Hello everyone - first post here ! I have a wiring question regarding the PCB 6x. I'm currently in the process of a new pedalboard build and acquiring all the materials and pedals including getting ready to order a PCB 6x. I've been reviewing the manual and trying to figure out if/how I can wire something. What I want to do is run the PCB to two separate amps. One of the amps is a "real" amp with an effects loop. The other would be a Strymon Iridium, which does not have an effects loop. This would enable to me use both a real amp or just take my board and go to FOH/power amp. I see in the PCB manual how you can send the PCB to two separate amps, both with effects loops using insert cables. The problem I foresee is that I would still like to use the Iridium having pre and post amp effects - exactly the same pre and post that I would have with the real amp/effects loop. But I'm not sure how I would put the Iridium in the middle of the effects, considering the output would go directly to FOH/power amp. I am putting junction boxes under the board for all the connections to amp etc. Does anyone have any experience or ideas how I would go about accomplishing this ? I am about to pull the trigger on an Iridium and I want to make sure this is going to be the right pedal for me, or do I need to find something else similar. Thanks in advance for any help - I appreciate it and look forward to a new PCB !
