The Full Nelsons
Not sure if this has already been posted (couldn't find it when I searched ) but the bug that was present in the firmware update allowing the Big Sky and Timeline to work with Nixie ( the bug made the pedal think that it was in Kill Dry when it was not ) is apparently fixed according to Matt at Strymon. I have not tried it yet as my gear is at rehearsal hall but here is his email reply:
Matt Alegrete (Strymon)
Nov 10, 15:56 AKST
Hello David,
Thank you for supporting Strymon.
Yes, actually we have a new version of firmware out now that solves this bug and keeps compatibility with Nixie. I am attaching the file to this email for you now (for both pedals).
To load them up, just drag and drop the firmware over the respective pedals in Nixie and they will install automatically.
Hope this helps!
Matt Alegrete
Customer Support
Strymon Engineering
www.strymon.net www.youtube.com/strymon www.facebook.com/strymon www.twitter.com/strymon www.instagram.com/strymonengineering
Attachment(s)
BIGSKY 1v44.syx TLDeuce 1v84.syx
David Weaver
Nov 8, 17:04 AKST
Hello. I was trying to use Nixie in the past and there was a known bug in the firmware update necessary to use the software that told the pedal it was in Killdry when it was not in fact in that mode and you had to go in and turn it off and on again to work. Has there been a fix for that problem or any movement forward to get a stable version going. It would very handy to be able to use this program for setting up the Timeline and Big Sky.
Thanks for your reply
David
Nov 10, 15:56 AKST
Hello David,
Hope this helps!
Matt Alegrete
Customer Support
Strymon Engineering
Attachment(s)
David Weaver
Nov 8, 17:04 AKST
David
