PBC/6X MIDI In Box Wiring Question
mrbesty
Hi all!
Sorry if this has been covered elsewhere (I searched, I promise!) but I wondered if I could confirm the wiring of the pins for MIDI in and out on the PBC/6X. I'm planning on building a little box as per the suggestion of one of the other forum members to split the port. Would I wire pins 4&5 from the PBC to 4&5 on the midi out port and 1&3 to lugs 4&5 on the midi in (then presumably pin 2 from the PBC to pin 2 on both ports)? I hope that makes sense!
I only have basic soldering experience with XLR, TRS etc. but not MIDI as yet so apologies if this is a bit basic haha.
Thanks in advance,
Michael
Here's the diagram we used when we used to build phantom power power boxes by hand. Since the PBC/6X doesn't use phantom power, you would need to replace the 7-pin connector with a 5-pin connector, and delete the power jack. The other connections remain the same.
  • PPA-DIN7F-2.pdf
YOU ROCK! Thanks RJM
Oh, this is excellent! Haven't got round to wiring mine up yet but this is super helpful.
Thanks heaps!
I went ahead and wired up my own split cable using the diagram above and it all worked! I ended up just making a split cable, not a box. I used BTPA's CA-1007 Mini Starquad cable and was able to fit both cables into one Switchcraft right angle midi plug.
The only problem on the wiring was a little confusion about what side of the midi jack/plug I was looking at. To make it easier on my brain, I ended up making my own diagram. RJM, check my work please! ;) If all is well, maybe this can be a useful resource for others.
