PBC 6X Split Mono Question
Hello, new to the forum, thanks ahead of time for any help.
Im doing the split mono on the (3) loops with insert cables, and had some difficulty on the last loop. Can you split a loop and have the tip as a dirt pedal going into the front of the amp, and put the insert loop in between that and a delay after the amps effects loop? Ive used known good insert cables and this setup keeps giving me no sound once i plug the return side in. It will produce a dry sound with the sends plugged in to both pedals, but once the return side is in it goes mute. Im using a Mesa Mark V by the way, and im not sure if the loop is parallel or not.
There shouldn't be any problem with that, it's definitely a configuration I've tested. Do you have the latest firmware? We did have an issue with split loops in earlier versions.
