scholl2512
Random insert cable question - If I run a mono signal out of my 6x while a stereo Y insert cable is plugged in, will that send my mono signal to both the tip and ring sides of that cable like it would a normal patch cable?
I have a really compact board set up in stereo but I'd like to run it in mono at times. Physically unplugging the insert cable on the PBC's output and using a standard patch cable is a pain. I'm running a Timeline/Bigsky in stereo after the PBC - those I can unplug cables fairly easily if I want to run in mono, just not the output of the PBC.
Thanks
Thanks
