I’m new to pedals as of the start of this year and have had a ton of fun working toward this setup. I can’t say enough about how great it is to have forums like this one, Reddit, and of course YouTube. I’m basically a bedroom guitar player (or office actually) and hoping to jam more often with some friends as I’ve gotten back into guitar.
Board setup is the Aclam S2 pedalboard with Wahpper second tier riser board. I’m using two CIOKS DC10 supplies, one under the main board, one under the riser. I bought the CIOKS supplies because Aclam had a mount specifically for that supply. American Loopers 6-way TRS Junction Box is under the main board. Patch cables are Goodwood Audio custom length TRS insert cables and EBS PG and TRS flat patch cables. Using all PBC loops in split mono. Loops for pedals on the riser are connected via TRS to the junction box, then broken out on the back side of the box. The setup can be quickly broken down and put in two bags.
I’m using a wet/dry setup where I have one loop send only to the dry amp, then using 4CM with the wet amp. Dry amp loop out and main PBC out go to the junction box. I can reorder the dry loop to be after the wet effects if I want both amps wet. Haven’t had any ground isolation issues, but guess I could buy an isolation transformer if it ends up being a problem.
Everything is in its own loop except the wah is on the front end before the PBC and the Muffuletta and the PackRat are in the same loop. The JamMan is on the board because I could fit it and uses its own external power supply.
The Saturnworks switch is set up right now to control one PBC function switch. One PBC external switch is connected to the Morning Glory red remote.
I’m not using midi yet. I’ve got the Disaster Area micro.clock connected to the Carbon Copy, DD-8, and Flint. I still need a solution to sync the micro.clock to the PBC tempo, if anyone has any suggestions. I thought I could use midi to send tap CC messages to the micro.clock, but from what I understand the fundamental clock rate that messages run on is not fast enough to get good enough resolution in setting the tempo. I think I could switch to the Smart Clock and use midi clock from the PBC, but the Smart Clock would have to go under the board because it’s much bigger than the micro.
I’m using a C13 computer style power cable with a C14-to-C5+C13 splitter under the main board to daisy chain the CIOKS supplies with a short C14-C5 cable to connect to the CIOKS on the riser.
Can’t think of anything else. Thanks for all the great support and contributions here!
