PBC10 in7-10 jack stereo?
Daniel Kim
Hi guys. Can someone advise me?
Can I input stereo to the pbc10's in7-10 jack port?
So can you actually use 5 stereo pedals?
in7-10
loop 7. 8. 9. 10?
Yes, you'll need an insert cable to do it (TRS spilt to two TS). Also keep in mind, that pedal will be "always on" unless you can control bypass on that pedal via midi, using a function switch or with your foot.
When doing that, make sure that the Mono -> Stereo (out) button is in the 'In" position - that will allow it to accept a stereo signal.
