Pedal Power 2
davisband
Can I power the mastermind with an original Pedal Power 2? I found one post stating the mastermind needs 100ma 9VDC but the spec says 200ma. The original PP2 has 2 outputs that can output 200ma but I believe its unregulated when you flip the dip switch so the current would be correct but the voltage may vary if not pulling the full amount.
The unregulated 200mA outputs should be fine - the Mastermind has its own internal regulation.
