Sorry if bug reports belong elsewhere, I didn't see anywhere for that. It seems the "Flash w/ Tempo" setting from Page 1 just applies globally to every other page, visually, but not functionally. Here's what I saw: if Ext Button 1 is set as a tap-tempo switch on page 1, that LED flashes on every page. But here's why I say its visual but not functional: if I set the tap tempo to Ext Button 2 on a different page, then tapping button 2 on that page WILL change the tempo (though button 1 is still the one that flashes, no matter what I set as the behavior for button 1); also, if page 1 has no tap tempo on either button, then those LEDs will not flash on any other page, but a button configured as tap tempo on a different page will still function to change the tempo, just no flashing. The LEDs on the unit itself work exactly as expected, this is only an issue with the EXT switch. Let me know if you need anything from me to diagnose/reproduce this issue. Attached file is my rjs settings file with the issue, though I have the tap tempo on button 1 pretty consistently on most pages since this is what I'm actually using, so its only visible on pages 2/3 where there's not supposed to be a flashing LED (and I change pages from an external controller so there's not really a way on-device to directly see the issue, but I could change the settings and re-send if needed)
