Thanks, but since I live in Germany, I try the dealer to exchange the unit. I think I could fix the stucked write button, but the amp switching for my Dual Recto also doesn't work.
The RG-16 is configured for Mesa Rectifiers. If connecting amp1 jack and footswitch jack of the Recto with the custom cable, the amp seems to try switching to two different channels simultaneously, which results in a buzzing noise. After browsing the forum, I checked the cable and it seems fine.
The behavior differs, when connecting amp2 jack -I can switch channels of the Recto with the function switch buttons of the rg-16. This way solo-boost can't be activated.
Channel switching + solo boost still works with my mesa standard footswitch.
Maybe the power supply is the culprit. I use a 9V AC adapter with more than 1A max output, but the power grid in europe works at 50 and not 60 Hz, so the adapters output could be at 50 HZ. I currently have no DC adapter with enough output power to compare. What do you think?
