Hi,
I guess I'm missing something.
I use The master mind to control the effect Gizmo on Midi Channel 1(PC1=Ch.01)in global setup.
When My G Major is on Midi Channel 1,It respond to the mastermind perfectly,but,of course,any CC sent to the Effect Gizmo,it is sent also to the G-Major 2.
Then,I Change the Midi Channel of My G-Major to Midi Channel:02
And also assigned PC2=Ch.02 on the Mastermind.
And nothing happens.The G-Major don't receive the programm changes.
Then I realise that.In PC1,All the preset are already assigned from 1 to 127
But for any other device,you have to assign it manually,preset by preset
Can I then send differrent CC using I.A mode to different devices?
example:If cc80 is assignes to loop 1 on the effect gizmo but cc80 is my tap tempo on the g-major...Is the Midi channel used for a CC will only affect the device on wich it is assigned?
is that right?
Sorry for my english,not my main language.
Thanx
is that right?
Thanx
