lbcbdr
the Mobius has a pre/post feature that, if I read it correctly, use the left and right I/o's as 2 paths that are switchable per preset. Their example is use left I/o for instrument to amp and right input in the effects loop of the amp. If the preset is set to pre then the mobius is in the left path, in front of the amp and the right path feeds from I to O. If set to post then vica versa the left path feeds from I to Oand the mobius is in the right path, the effects loop. If you were to connect it to 2 loops on the PBC say one before the "gain/distortion/fuzz" pedals and one after those you could set say a wah preset to be pre and turn on the early loop so the wah is before the gains. And a chorus preset to post and turn on the later preset to have the chorus near the end of the chain. Does this sound like it would work?
