Let me know if this works.If someone could get me the default list of CC numbers from the pedal, I could do it. Boss doesn't publlish that list, as far as I can tell.
Unfortunately not. They have all of the MIDI information in there, except for the stuff i need. :-\
Hi Ron, I searched and could not find what you needed, so I went through one by one and added the cc#'s. I made a spreadsheet and attached it to this post. Please let me know if this is what you need. I appreciate your help.Unfortunately not. They have all of the MIDI information in there, except for the stuff i need. :-\
What I need is the contents of the MIDI CC menu on the device.
Thanks! Are these the factory defaults on the pedal (you didn't change them)?Hi Ron, I searched and could not find what you needed, so I went through one by one and added the cc#'s. I made a spreadsheet and attached it to this post. Please let me know if this is what you need. I appreciate your help.
I changed nothing. I just scrolled through them on the pedal one by one.Thanks! Are these the factory defaults on the pedal (you didn't change them)?
I love the sound of this pedal so much but the menu is brutal to decipher.
Have you gotten any of the MIDI CC messages to work on the SDE-3000? I'm trying to get the footpedal volume to work (FV.PL.PoS on edit menu) at its assigned controller 95. It ignores the MIDI. The MIDI clock and MIDI PC work fine, and controllers from the RJM to other pedals work fine, so it its definitely the boss unit or my setting of it.I love the sound of this pedal so much but the menu is brutal to decipher. If this was populated on your app with the options that would be amazing. Thank you for the consideration.
I have got the CC messages to work on some parameters, but have not tried the foot volume pedal.Have you gotten any of the MIDI CC messages to work on the SDE-3000? I'm trying to get the footpedal volume to work (FV.PL.PoS on edit menu) at its assigned controller 95. It ignores the MIDI. The MIDI clock and MIDI PC work fine, and controllers from the RJM to other pedals work fine, so it its definitely the boss unit or my setting of it.
