vertigocycles
I have a couple of issues that I hope I can get some help with.
I've spent some time capturing sysex messages from a TC2290, specifically for the External Effects on/off functions. I've captured them, paired down the messages as much as I'm able and have been able to successfully make them work from Sysex Librarian.
I created a sysex message in the MMGT Editor with the following: F0 33 33 05 0F 0F 05 F7 F0 33 33 05 00 01 F7 (this is the command to toggle the on/off state of loop 1) and then created a button assigned to the 2290, with a Sysex action that refers to the appropriate line in the Sysex table. The on and off message is the same since it's a toggle. The message doesn't affect the 2290. I wired the MMGT up to my laptop to check the outgoing message and it's correct.
Any guesses as to why it's not working? The MIDI channel is correct on both devices, I'm able to send PC changes just fine so it would appear to be setup correctly. The 2290 is setup to receive Sysex messages and midi messages. I'm confused.
The second issue is this...
I was able to get the command for the first loop down to 15 bytes but the other four loops seem to require significantly more information and are over the limit for each sysex entry. I read that a full message can be split into several messages but how is this supposed to be setup so that one button press can send 3-4 messages in succession?
