Updating Devices
pidgyn
Hi,
I have been using Chase Bliss Audio Brothers Analogman for a while and I just updated the editor and found this device is now available in the newest update.
Before I had a regular Brothers pedal selected in the Devices section but now that the analogman version is there I wanted to change it.
The problem is that when I select a new device, all the PC numbers that I had saved in presets are missing and they are changed to numbers from 1to121 and then repeated again after 120 presets.
Is there a way to maintain the PC numbers when changing the device model without having to write it all down and put it in the program manually?
Thank you
Unfortunately, it looks like it will always reset the PCs to be sequential when you change device types. If you'd like to send me your settings file, I can manually edit the file, only one byte needs to change. The trick is knowing which byte...
