Using mono out for single amp setup while wired in stereo
William Kim
Hi,
I have raised a ticket for this particular question but I thought I'd post the same question here so that others with similar queries may benefit. There is always a chance that this has already been asked and answered but here goes:
I am trying to connect all my wet pedals in stereo (currently wired in mono [left mono out]) through the loops 7,8 and 9. My wet pedals are Walrus Mako D1 (to arrive) > Strymon TL > Strymon BS and I am planning to connect all three via insert (1 TRS to 2 mono TS) cables as depicted in the product manual.
Here is my question:
1. As I sometimes use 1 amp only for smaller gigs, can I put PBC and my 3 wet pedals in mono while leaving the wiring in stereo to get a perfect mono signal out through PBC mono/L out to amp? All 3 of my wet pedals support mono mode.
2. In the above scenario, can I still use the parallel mixing function of PBC?
Thanks for your help!
Will
Yes to both questions!
If you don't use ping-pong or panning effects, you don't need to do any of that, you can just leave it all stereo and just use one output from the PBC to go to your one amp.
