I am experiencing an issue that I have not had before. When I run Loop 1 into Loop 2 I get a massive volume and tone loss. If I turn off the pedal in Loop 1 (keep pedal in loop 2 ON), the issue goes away. If I turn off pedal in Loop 2 (keep pedal on in Loop 1), the problem remains. When I run Loop 2 into Loop 1, then I don't experience this issue.
At first, it seemed obvious, the problem was the pedal but I have tried both the pedals before and after each other Guitar>pedal 1>pedal 2>amp and Guitar>pedal 2>pedal 1>amp (without using switcher) without issues.
I also swapped the pedals in loop 2 and loop 1 and the problem remains that whenever I run loop 1 into 2, the problem occurs, no matter what pedals are in the loops.
Could there be a setting somewhere that I am overlooking? Maybe reinstall software? Or would this be a hardware problem?
