Correct.Sorry to resurrect this thread, but just want to confirm there's no other option/approach I could take.
I have a PBC6x, a lehle mono volume S and a dunlop volume X mini. I want to have a volume pedal and an expression pedal on my board.
1) First question that serves as the foundation for the rest. Am I correct in understanding that if I put a volume pedal into a loop in the PBC6x (let's say loop 4 for example, i.e. after my 3 duzz/drives), it will function as a volume pedal would normally in the chain when the loop 4 is engaged, and the volume pedal would cease function/use when loop 4 is turned off/removed from the chain?
Probably the best way to do this is to use the pedal as an expression pedal, and switch it to sending MIDI messages to a pedal or VCA that can control volume level when you need it to work as a volume pedal.2) To save space, is there anyway to set it up so I could have one volume pedal function as EITHER a volume pedal or a expression pedal depending on the preset? If so, how would I wire/accomplish that?
If your volume pedal has a separate expression output, then it should work.This is how I think it would work, please let me know if my thinking is correct: I could wire the pedal for volume and place it in a loop, and disengage that loop whenever I don't want it to be functioning as a volume pedal, and then I'd separately separately have a (a TRS out from Aux send on the Dunlop Volume X Mini) OR the USB-C to USB-B of the PBC6x [or does it have to go to the expression in via a USB-C to TRS cable?]) the same pedal be used for expression over midi to my various pedals (strymons, etc.) on presets when desired.
Will this work?
If you need the volume pedal to be switched out, then it needs to be in a loop somewhere. The MIDI loop switchers you mention would work fine.And is there way I can do it without 'sacrificing' the insert loop to the volume pedal only? I'm not seeing a way.
USB on the pedal isn't going to work with the PBC in any way that I could imagine.3) (reasking the question buried above). Will the USB-C out on the Lehle Volume S send midi expression to the PBC-6x if I connect it to the PBC's USB In via a USB-C to USB-B cable? Or will a USB-C to TRS cord work if I plug it into the PBC's expression in?
No problem!Thanks as always. I'm continually amazed how responsive RJM is to questions like this.
