Which jack goes to Amps RETURN in Loop???
Don Anderson
I’ve got In7/10 going to Send of Loop but the manual does not say which one goes to the Return
it says Out 5/6 goes to In put of the amp
-that’s not the Return correct? I take InPut to mean In put on front of amp
Sooo which jack goes to return?
To clarify the manual does not say what the Out put A or Output B go to
That’s either to the Return of the Loop or to the Input of the amp
See pic from rear panel please clarify:
Does Out 5/6 go to Input -Front of amp or???
And the OUTPUT A or B to ???
If you want the pedals in 1-6 to be in front of amp and the last 7-10 in the loop then you send 5-6 out to front of amp. Connect the amp effects send to the input of 7-10, then the output A or B to the return.
