A button to start a midi sequence that can be run either looped or a set number of times and can be tap tempo based. Started and stopped via a button press.
A use case could be sending CC messages to a Digitech Whammy to set the treadle position so you can strike a note and it would be manipulated in sequence to create and effect like Map of the Problematique by Muse (I know this isn't a sequenced whammy but gives the idea).
I know this is a feature that's about to be released on the Gig Rig G3 and apart from the Molten Midi 5 and the discontinued Evenmidi Pitchy there isn't anything hardware based that can do this.
Hopefully that makes sense.
Thanks, Matt
Thanks, Matt
