Ron,
Please let me know if this configuration is possible with the PBC.
can I have loops 7-10 set up for parallel processing in mono for two different purposes?
For example, I would like to be able to use 7-10 for mono parallel fx for all instruments I use because of its series parallel routing options. Where it gets fuzzy is I would like to use it in 1) my amp send/rtn path when I play electric (using out A) but also use it when playing acoustic (using out B). Is this even possible? Would I need to to use the tip side of the 7-10 input for the electric send/rtn path and use the ring side for the acoustic path, essentially creating 2 discrete mono paths thru 7-10? Or am I completely missing the boat here and will require a separate switcher (which I don't think I have room for on my board).
