Amp Gizmo+3 amps doubt!
adrianher
Dear people fron RJM forum, I'm new on these forum and I've got some doubts that I hope someone can solve them.
I've bought an amp gizmo to control my EVH 5150 III throught a TC Electronic G System.
Now I've got a JCM900 MKIII and a Marshall 30th Aniversary.
My doubt is these is any way to control the 3 amps with AMP GIZMO, considering that I use a custom RJM cable for the EVH and 30th aniversary has midi footswitch. Input too.
If anyone can help me the way to connect that amps.
Add info: EVH has 3 channels, 30th aniversary has 3 channels and jcm900 has 2 channels.
Really thank you
assuming you have the amp gizmo and not the miniamp gizmo it should be easy
Amp control output 1 to one JCM900 MKIII
and amp control output 2 to Marshall 30th Aniversary.
obviously you will need the custom cables for both amps
the use midi thru to the EVH and control that via midi
A little amendment - the 30th anniversary has MIDI, so you can connect it via MIDI, no need to use the Amp Gizmo. The 5150III has MIDI if it's a 50 watt model, but not if it's the 100 watt model. If the latter, you can connect it to the Amp Gizmo's "To Amp" jack with our 5150III interface cable. The JCM900 can connect to the Amp Gizmo using a 1/4-inch cable connected to the Switch 7/8 jack of the Amp Gizmo.
Let me see...if I connect these way would be ok?
Jcm900 to amp gizmo, throught 1/4 jack
Evh 5150 iii 100wts to amp gizmo, via custom cable to "to amp"
Marshall 30th to amp gizmo throught out/throu with a midi cable
Really thanks for fast response!
