Every once in a while, we come across a Mark V, Rectifier, Road King or Roadster that doesn't work correctly with our Amp Gizmo. The symptom is that the amp will sometimes switch between two channels very rapidly. Most of the time, we can fix it by replacing the cable, but the same cable that was causing the problem will work fine with other Mesas. There must be some variance in the amps and in the cables themselves that causes the problem to happen with the right (or wrong) combination.
Every time this has happened, the amp was far away so I couldn't test it for myself and get to the bottom of the problem. It's a long shot, but t was wondering if anyone in the US has one of these amps that exhibits this problem. I'd love to either rent or buy the amp so I can finally figure it out. If you have an amp like this, please let me know!
