when I press button 2 and so on it just goes back to 1. It flashes the presets number for half a second and just stays at 1. Even when I bank up and press any button it goes back to 1.
Check MIDI Receive Channel in the GT's global settings. It should be set to None. If that's not the issue, please send me your settings file and I can figure it out.
The setting file looks ok. Make sure that Program Change and Send Realtime Sysex are both turned on in the Axe-Fx's MIDI settings. Also make sure its MIDI channel is set to 1 (in the Axe-Fx MIDI settings).
