Franklin
Hi All,
New to both the AxeFX and the GT22 and have 2 questions. I’ve followed the instructions in the manual and (1) can’t seem to figure out how to connect the gt22 via usb to my mac in order to use the editor and (2) I can't connect a mission sp1 to the GT22. Both midi cables are connected and I’m using the latest firmware (4.1 beta).
(Expression pedal – WAH config) I’ve set default pedals, calibrated, assigned cc, set position. When I touch the pedal the wah block on my axefxIII will activate but the wah sound is not good. Theres no action or “sweep”. It’s like the wah turns on and stays in the heel down position. When I move the pedal up and down I can’t sweep across the frequency range.
(Connecting via USB B to my mac) If I try to sync (Transfer > connect to device) I get an “Unable to connect to device” message. I’ve changed the Midi Port parameter to USB. I can’t connect to the device, read settings from device, or write settings to device. Am I missing something?
