Bogner Goldfinger channel/verb/boost(s) switching solution
Hey Ron,
Trying to figure out what the least expensive, and best solution is for switching my bogner goldfinger via my MM PBC. I suspect it is with an Amp Gizmo. How would that work as far as incorporating it into my pages on my PBC? Im approaching a point where i need more instant access to things than i have buttons. Any suggestions would be appreciated.
Thanks,
John
You could get away with a 2xTRS to 7-pin DIN cable made for the Goldfinger. The Goldfinger uses 4 switches, so the built in switching in the PBC is enough. We could get one of those made for you, or you could contact Best-tronics (www.btpa.com)
In that case, you could use the existing function switch buttons on the Switches page. Of course, they could be moved elsewhere if needed.
