Ray Liptak
Hello,
Can I change the factory CC's that are supplied w/ the Axe FX3 pedal firmware in my LT? I upgraded to an FX3 from an XL+ and all of our effects are triggered by our ableton tracks which are currently programmed w/ the CC #'s from the XL+. Unfortunately the upgrade came after our first month of shows so I'm stuck w/ the CC #'s that I have programmed for most likely the next 2 years!
I tried the learn function with the old CC #'s but the 3 did not respond. I also tried putting the CC #'s that I wanted in manually in each buttons action parameters section, but the LT changed the corresponding button to a different effect.
Thanks in advance.
(example, CC# 41 was the chorus 1 bypass from the XL+ and in the new firmware CC# 41= input USB)
Thanks in advance.
