Chuck Hanning
So starting a new question here. I previously have set up two Midi device pages to talk to each midi device and overall works well. I had used Ron's template which has device PC+/- buttons as normal functions and bypass as the hold functions. That works great for my H9 and Timeline.
For the chase bliss peals (I have a wombtone mk2 and warped vinyl mk2). I would like to set up the buttons slightly differently. For the normal function they can stay as pc+/- but for the hold function, I would like to send the PC message of 0. This puts the chase bliss pedals into live mode and would allow you to tweak buttons to find the sound you want. Then when you're done, press the hold function again and it would take you back to the last pc command you had cued up (say pc of 6 or something). If when you're holding the tap and bypass buttons on the CB pedals, that should then write the settings you had just figured out to that program number (e.g. 6).
I have been working on trying to do this but there are some other parameters I am not familiar with under the hold function. I got the PC and then device, but there are then on program and off program numbers. Right now I have them set as "0" and then "same", respectively but I'm not sure that's right.
Help is always appreciated!
Chuck
Chuck
