I am having a little bit of a problem I am hoping someone can help with.
Current set up:
I have been using the line out of two amps to go into loops 7 and 8 on an RG-16. The send of both of those loops goes into two of the input pairs on a mini line mixer. The output of the line mixer goes into a g-force that then goes into a 2:90 into wet cabs. No problems. I am now select if I want amp A to feed the G-force, Amp B to feed the g-force or both amps.
Changes made:
I am trying to slim things down and changing stuff to make it jsut a one amp W/D/W set up. I have removed the Amp B from the picture all together. Loop 8 is no longer in use.
Hence I no longer have the need for the line mixer in this situation. (Intention is to allocate it to a differnt purpose that I also ahve a question on but that is for another day)
I have remvoe the mini line mixer altogether and now the line out from Amp A goes to the input of loop 7. the send of loop 7 goes directly into the g-force and then into the 2:90 into wet cabs. It works fine except. Now I get a click /pop sound when turning loop 7 on/off from an instant access switch on the rocktron AA. where I dont get the click/pop when running into the mini line mixer.
In advance thanks
Boof.
*updated info
I checked the following and only when adjusting the G-force output level did it make a difference (G-force input and output levels are generaly kept straight up around "noon"
(PT-100)
Level change: no effect on pop/click level
Return change: no effect on pop/Click level
CAE Line out box level: no effect on pop/click
G-force output level: YES. increased output=increased pop/click level.
Pics below to help illustrate
Current: (no Click/pop)
New (Click/pop)
Current set up:
Changes made:
In advance thanks
Boof.
*updated info
(PT-100)
New (Click/pop)
