libertystudios
Hello everyone I'm writing from Italy and I am new to the forum.
I have an annoying problem with a pedal (Wampler Ego compressor).
The pedal connected directly to the amp is working properly.
My system is composed of 8 pedals, then I go out from Cs and I return to loop 9 and 10 to switch Between Two amps.
Each pedal is working properly.
The problem comes when I turn on the loop 1 (ego compressor), the volume decreases. The volume return normal when i turn on some other loop.
If I go out from loop 8 and I go in to loop 9 without CS, everything is good.
I checked cables, voltage everything is OK.
I've an other compressor (demeter compulator) in loop 2 and works fine.
Any suggestion???
P.S: I use the front input with buffer
Best regards
Andrea
Any suggestion???
Best regards
Andrea
