Budro Thedog
I have an IA switch that I use to engage a loop on my effect gizmo to send my signal to an amp. I also have the IA setup to turn off the AXE AMP and CAB blocks when I turn on my real amp so it doesnt mess up the sound.
AXE-FXIII: Amp 1/ CC Toggle #58 off:127 on:0
AXE-FXIII: Cab 1/ CC Toggle #62 off:127 on:0
Everything works great when I press the I/A switch. However, when I change presets, I run into an issue where the amp and cab blocks of the new axe preset are not turned off, even though the IA on the MMGT has "send on preset change" on.
Currently for that IA, I have the Update On Preset Change should be OFF and Send on Preset Change On.
Is there a way to have the midi cc's sent to the Axe when I change presets so the axe amp and cab module turn off?
