I finally finished a video showing how to set up a PBC to control a Strymon Timeline, including the looper. You can find it here:
PBC Timeline Video
PBC Timeline Video
Can I assign the recording button to also do the overdub when pressed a second time. How about the play loop to re-trigger the loop.
Hi poole. I'm having the same problem...looper doesn't seem to engage when I go to page 4 and his record. Can you please tell me how you fixed it? Thanks.Just in case you were going to get back to me...some perseverance and I've gotten things worked out now so all good. Thanks again for the video upload.
Hi everyone- Just so you know this is a typo on strymon's website. The level value goes between 0-127 like most midi values. At only 17 you barely hear the loop you made, whereas 127 is the full volume you made it at.Hi all- I know I'm several years later but had question about using the expression pedal connected to my PBC10 to control the looper level.
I got this set up for my Eventide H9 but there are somethings about it that might be easier using the TL (which I also have), so I am playing setting up both.
I have set up the record, stop, play, undo, redo, speed, and reverse as Ron describes in his video from some time ago.
On this page from Strymon (https://www.strymon.net/looping-with-strymon-timeline/), they also mention that the looper level can be controlled by midi cc#98 value 0-17 for the looper level. I have an expression pedal connected to my PBC and was wondering how I set that up to control the level.
I am using one of my buttons on the external button switch (set in Global) with IA cycle to control the TL Looper. To control the level should I:
1. in the IA actions, I use CC (toggle or momentary?) to control CC 98 set between 0 and 17, but how will the PBC know that it is meant to be controlled using the expression pedal not a switch going between 0 and 17?
2. Or in the IA actions do I use System/Exp Pedal/ with off value of 0 and on of 17, but then how do I select that the expression pedal should control cc 98?
The H9 has a similar idea with parameter 1 controlling the mix, which I wasn't able to figure out either.
Has anyone done this? what should I do?
