deelydian
I'm in the process of re-wiring my pedalboard, and I'm wanting to run a stereo set up with my UA Ruby and Dream. I know this will be easy if I simply run all effect before the two UA pedals, but I'm also wanting to try out having the wet effects after the Ruby and Dream. In order to do this, I need to have a split signal going into the mono input of each pedal, then run both outs into a TRS plug back into the "In 7-10" jack of the PBC.
I'm pretty sure I know the answer to my question already, since the manual says nothing about being able to run a TRS out of the "Out 5-6" jack to split your signal. However, I thought I would ask just in case I'm missing something. Is this possible, or do I need to get a buffered splitter to accomplish it?
Also, just to be sure I'm not missing something else, am I right in how I plan to go back into the "In 7-10" jack? As long as I take both signals from the Ruby and Dream and hook them up to a TRS plug, I can take that signal and go parallel stereo through all my wet pedals in loops 7-10, correct? With this setup, I'll be able to pan the Ruby and Dream left and right in the mix, correct?
