eljodon
Hi I just purchased a Effects Gizmo and I'm running 8 pedals from Loop 1 through 8. Before I usually used the ISP Decimator G string just for the pedals were I hook the output of the Decimator to the fitst pedal then the input of the Decimator to the out of the last pedal. Then I plug my guitar into the middle jack on the right side of the Decimator then the out from the left of the Decimator to my amp. How can I do that with the Effect Gizmo? Can I also hook it up using a loop to switch it on or off via the Effect Gizmo? I also sometimes use a Hush 2C on the effects loop of my amp and I would like to also be able to switch it on or off. Is there a wy to do that? Thanks
