I sent an email to the RJM support. Ron Menelli from RJM support answer me in 5 hours Charley Polacheck from Bogner support answer me too. Here I post my question + both answers and develop the question more.
Thanks to both of them!
My innitial question:
Ron Menelli:
Charley Polacheck:
I'm curently building a switching system with a RJM Effect Guizmo and a Bogner Ecstasy 101B.
I bought a medusa cable to plug thefootswitch input of the Ecstasy to the Effect Guizmo output's n° 9,10,11 and 12 in order to use switching latching system.
I'll programm that this week end but I still don't know if it will work properly. Do you know if these 2 items are compatible?
When I'll switch for exemple the chanel n°1 I'll send an impulsion to the jack 1 to enable the chanel 1. Afterwards, when I'll want to enable the chanel 2 I'll send an impulsion to the jack n°2 to enable the chanel 2. But THE QUESTION IS: Will I have to also send an impulsion to jack n°1 to disable the chanel 1?
Ron Menelli:
Hello,
The medusa cable will work with loops 9-12. You can on;y switch 4 functions this way, but it will work. For the channels, you need to set the switches to be momentary, which takes only a few seconds and is described in the manual. You also should use the grouping mode to make the channel switches work together - once you do this, activating one channel switch will deactivate the others.
Charley Polacheck:
This device should work. We don't have the RJM unit here, so you must contact them regarding functionality. Keep in mind that the channel switching is momentary and the rest of the functions are latching.
Thanks,
