Effect Gizmo tuner issue
prs1999
Using loops 1 thru 4
5 thru 7 and #10 in the amps f/x loop.
Plug amp into "output5-8" or CS out.
Plug in a Korg rack tuner and get nothing but added noise.
Anyone have an idea?
Thanks,
~ JB ~
The tuner output is an additional output from the buffer. Are you using the buffer in and out?
Ok, you'll have to route your signal through the buffer to get any signal out of the tuner output. Otherwise. you'll have to connect a loop send to the tuner input. That'll allow you to use the tuner when the loop is activated.
Sorry for this question,but how do you route the signal through the buffer?
(as in what goes in,or out etc.)
Thanks Ron
Your guitar signal should plug into the front input, or the Buf In jack on the rear. That's all that should be required.
Ok, figured that it was internally bridged.
I must have a grounding issue then with the tuner that I have never had before.
Already tried the "lift" on the Effects Gizmo with no change in noise.
If you have an isolation transformer like a Hum Eliminator, it would be interesting to try it between the tuner and EG output and see if it helps.
It came down to being a ground loop issue.
A .79 cent grounding adapter fixed it. Gotta love a cheap fix.
Thanks for the help Ron,
~ JB ~
~ JB ~
hi prs1999, how do you fixed it? please share the cheap fix option (.79 cent sound super cool)
thank you
