Hi guys,
I had a question about using an expression pedal with the PBC. I've decided to go back to a more traditional pedalboard and amp setup from using the Axe FX and the GT and when I used the the Fractal EV-1 expression pedal with the GT I would setup a vol block in the fx loop of my amp and that would act as my volume pedal for my rig.
My question is really to do with delay trails. When I used the axe, when playing a solo for example with a delay sound and I would end a phrase on my guitar I would move the vol pedal to the heel down position so it was turned off and the delay trails would keep going until they faded. Can I do that on the PBC using a timeline and a mission exp pedal for example?
I have a small pedalboard setup at the moment without the PBC and I've tried using a Mission VM-1 Pro into the fx loop of my amp with the time line and the delay trails don't seem to carry on when the vol pedal is turned off. It does when placed at the front of the amp. I'm guessing this is because it's a vol pedal and not an expression pedal? And they don't behave the same way in an fx loop of an amp?
I'm planning to add the PBC very soon and I just want to make sure before I start connecting anything.
Many thanks
Paul
Many thanks
Paul
