mcvittym
The Mastermind PBC is fantastic! However, I'm having a problem with programming the function button. It came set to switch on the global preset. I can't find anything in the OS X app to program it, but when I used the setup menu on the PBC itself to change it to a tap tempo button, it started operating as a tap tempo but also retained the 'global preset' property. I then tried programming it to switch on a (non existent) mini effect gizmo and then reprogrammed it to be a tap tempo button. It seems to be 'stuck' as a mini effect gizmo button and I can no longer access either the global preset or the tap tempo using the function button.
I am currently connected to the Mac via USB and am running the PBC editor in a Mac OS X session. I'm running firmware 1.0.2 on the PBC.
Can you help, Ron?
Thanks
Martin
Can you help, Ron?
Thanks
Martin
