I put together my Rack Gizmo controlled switching rig today. I am using an EVH 5150 III with the rig.
The issue I'm having is: Whenever I turn any effect on in the effects loop of the amp, I'm getting insanely loud ground hum.
I have the effects hooked up all in inserts 5-8; one pedal, my ISP Decimator G-String, is both in front of the amp and in the loop.
The pedal in front of the amp do not have the hum issue. This leads me to thing there is a ground loop in the effects loop portion.
I am using a Voodoo Labs PP2+
This is what I can say about my problem.
-I tested all of my cables through a guitar amp prior to hooking them up, and everything works without a doubt, and no leads are reversed, nor are there any poor connections.
-I tried lifting the ground on one side of the cable going from the effect return of the amp to the Rack Gizmo OUT 8/NO ; it did not work.
-I tried lifting the ground on one side of the cable going from the Rack Gizmo In 5 to the amp's effect send; it did not work.
-I tried pressing the ground lift on the back of the Rack Gizmo; it did not work.
-I tried moving the unit in the rack case/floating it with my hands to make sure it wasn't a rack ground issue; it was not.
-By turning the power off to a pedal while the respective loop was on in the effects loop, the noise went away
-The hum is not minor, but so loud the amp would be unplayable
If you have any suggestions, it would be very very welcome. Thanks again for the great support.
Cheers,
Greg
Cheers,
Greg
