Lp59
I have a preamp boost in the amp block controlled by Ext.4 in my Axe FX III.
Presets are saved with Ext.4 to Off, without boost, if I activate Ext4 with an IA switch the boost goes on, but if I switch back to another preset the boost is gone (normal off position) but if I activate the boost again, the first time I press the IA sw it will do nothing, if I press a second time the same IA sw. the boost goes on. I need 2 press of the IA to make it work.
I played with "Reset PC" on and off within the ext. sw. menu in the Axe, played with "send on preset change" and "update on preset change" in the GT without success.
How should I do to have the IA's assigned to ext. sw. behave normally. Thanks.
