Hi guys,
I hope you are all having a good holiday.
I need a bit of help with some switching issues I'm having with my Boogie Mark V35, axe fx, mini amp gizmo and GT.
I have 7 scenes setup in the GT via the IA menu, I've setup actions to toggle the various mini amp gizmo functions which all work fine.
The problem I'm having is when I go back in to preset menu and change to another preset or the previous one my amp stays on chan 2 when I want chan 1. If I hit the IA menu and select a scene the amp channel will change to the correct one. I can change channels via the mini amp gizmo itself but when I try to write changes nothing happens. If I then try to change presets the same thing will happen the amp will switch to chan 2.
I can see the amp trying to change but it just goes back to chan 2. This happens on power up as well, as soon everything is on the amp defaults to chan 2.
Any ideas what this could be?
Many thanks
Paul
Many thanks
Paul
