mauroxcastro
Hi! I have a question about wiring my pbc/6x with my hx stomp and need some help!
I use my Hx Stomp as an amp modeler and some effects. I know that the Hx Stomp have fx loop stereo, so I was wondering if I can do a double 4 cable method?
I want to use for example, FX Loop L as first on my signal chain, before the amp modeler and use the FX Loop R after the amp modeler. I know that I have to use the blocks in the Hx Stomp.
My question is if I can use the insert loop split from the PBC/6x, and connect there the FX Loop L and R.
The signal chain is:
Guitar In -> IN PBC
PBC Loop 1 -> Seymour Duncan 805
PBC Loop 2 -> Bondi Effects Sick As
PBC Loop 3 -> Zvex Distortron
PBC Loop 4 (split) -> Jhs Emperor
PBC Loop 5 (stereo) -> Strymon Timeline
PBC Loop 6 -> Walrus Audio Lore
PBC Loop 7 (split) -> Death by Audio Space Bender
PBC Insert Loop Send L (split) -> Input L Hx Stomp
PBC Insert Loop Send L (split) -> Input R Hx Stomp
Send L Hx Stomp -> Insert Loop Return L PBC
Send R Hx Stomp -> Instert Loop Return R PBC
PBC Out A -> Return L Hx Stomp
PBC Out 2 -> Return R Hx Stomp
I will use the PBC's loop reordering to place this two Loops where I want before and after the amp from the Hx Stomp.
I don't know if this is right. Is it possible?
Guitar In -> IN PBC
