Chris Green
I have a Revival Drive Custom and a Revival Drive Hot Rod Custom. I'm controlling them both with the PBC10 using a Kossek FX Dual Revival Drive Midi Interface. It can switch all the functions of a Revival Drive Custom via midi. Each channel of the Revival Drive has 4 on states and there's one off state, for a total of 9 PCs. RD Midi IF Preset manual attached if you need to see the Midi implementation chart.
I would use Device PC - & +, like I do for Strymon Timeline & Mobius, as you can see them cycle through patches, but the Revival Drive only shows channel 1 or 2 active or Bypass on the pedal. You can't see the blend override or mid boost on the Revival Drive. I do have LEDs for each state on the Kossek FX interface, but can't fit it on the surface of the board unfortunately. It has to go underneath.
I've just figured out how to set up IA Cycle to scroll through Bypass > Channel 1 > Channel 2 and back to Bypass using 3 of the 4 steps which is great.
Is it possible to set up one button to IA cycle through the 4 on states of channel 1, and a second button to IA cycle through the 4 on states of channel 2 and use groups to only have one PC from the 2 buttons active at a time? Could you also use the hold function to access a 5th state?
Chris
Chris
