ZappaFrank
In the Preset Audio Settings of the PBC6 it is possible to switch both inputs off. Why isn't it also possible to switch bot inputs on?
A workaround would be to copy all presets with input 1 and change them to input 2, but it would be easier to just have the option to switch both inputs on. I am aware of the fact that I don't get stereo input. I would use the input 1 as my standard input and input 2 as input for my ditto looper which sits outside of the loops of the PBC6. And while you can send a CC to switch outputs on and off, you also can not do that for inputs which adds to the lack of flexibility with regard to input switching. I guess a workaround would be to define for each input 1 preset an alternative input 2 preset and you can for example activate the alternative preset with input 2 on double pressing the button of the preset 1, but again I just wonder why you can not directly define in each preset that it should use input 1 and input 2.
