i had a mini amp gizmo controlling my mesa roadster. i bought the rg16 and i am using the same cable, is this ok? worked fine with mini amp gizmo, but rg15 is not turning on loop button or solo button. any suggestions?
The cable should work the same way with an RG-16. Make sure your power supply is 9VAC or 12VDC. 9VDC will not work, and the symptom is that some loops/switches will activate properly and some won't.
